Panasonic DECT 6.0 Button Replacement
  1. Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: step 1, image 1 of 3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: step 1, image 2 of 3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: step 1, image 3 of 3
    • Remove the battery cover by pushing the tab upwards and sliding it off.
    • Pull out the battery/energy source from its slot.
    • Keep all pieces in a safe and orderly manner for ease of reassembly.
  2. Panasonic DECT  6.0 Button Replacement: step 2, image 1 of 3 Panasonic DECT  6.0 Button Replacement: step 2, image 2 of 3 Panasonic DECT  6.0 Button Replacement: step 2, image 3 of 3
    • Unscrew the screws you see on the inside of the casing using an appropriate screwdriver from the JIS Driver Set.
    • Carefully pry each side open with the iFixit Opening tool.
    • Detach the back of the phone case.
  3. Panasonic DECT  6.0 Button Replacement: step 3, image 1 of 3 Panasonic DECT  6.0 Button Replacement: step 3, image 2 of 3 Panasonic DECT  6.0 Button Replacement: step 3, image 3 of 3
    • Unscrew the screws to remove the motherboard using an appropriate screwdriver from the JIS Driver Set.
    • Potential for device damage
  4. Panasonic DECT  6.0 Button Replacement: step 4, image 1 of 3 Panasonic DECT  6.0 Button Replacement: step 4, image 2 of 3 Panasonic DECT  6.0 Button Replacement: step 4, image 3 of 3
    • Carefully pull off the circuitry and cords from the front half of the phone and set them aside.
    • Bring the buttons to the front.
  5. Panasonic DECT  6.0 Button Replacement: step 5, image 1 of 2 Panasonic DECT  6.0 Button Replacement: step 5, image 2 of 2
    • Pull gently to separate the button pad from the phone cover.
    • Identify the broken/jammed button you were having issues with.
    • Replace or return the button to its function.
Jacob
131 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 10
All Time: 536
