Panasonic DMP-BD89 Exterior Cover Replacement
  1. Panasonic DMP-BD89 Exterior Cover Replacement, Disk Tray Cover: step 1, image 1 of 2 Panasonic DMP-BD89 Exterior Cover Replacement, Disk Tray Cover: step 1, image 2 of 2
    • First, before powering off, press the eject button to open the tray.
  2. Panasonic DMP-BD89 Exterior Cover Replacement: step 2, image 1 of 3 Panasonic DMP-BD89 Exterior Cover Replacement: step 2, image 2 of 3 Panasonic DMP-BD89 Exterior Cover Replacement: step 2, image 3 of 3
    • Remove the front cover of the tray.
    • Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
    • Then slide it vertically up and away.
  3. Panasonic DMP-BD89 Exterior Cover Replacement: step 3, image 1 of 2 Panasonic DMP-BD89 Exterior Cover Replacement: step 3, image 2 of 2
    • Press eject button to close the tray.
    • Make sure to unpower and unplug device before continue work on other fixes.
  4. Panasonic DMP-BD89 Exterior Cover Replacement, Exterior Cover: step 4, image 1 of 2 Panasonic DMP-BD89 Exterior Cover Replacement, Exterior Cover: step 4, image 2 of 2
    • Using a Phillips #1 screwdriver, unscrew the back three screws.
  5. Panasonic DMP-BD89 Exterior Cover Replacement: step 5, image 1 of 1
    • Slide the top panel horizontally to remove it.
  6. Panasonic DMP-BD89 Exterior Cover Replacement: step 6, image 1 of 3 Panasonic DMP-BD89 Exterior Cover Replacement: step 6, image 2 of 3 Panasonic DMP-BD89 Exterior Cover Replacement: step 6, image 3 of 3
    • Locate 6 tabs across the device.
    • 2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
  7. Panasonic DMP-BD89 Exterior Cover Replacement: step 7, image 1 of 1
    • Pop the 6 markers out.
    • Then take off the cover.
David Sun
213 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 11
All Time: 273
