Remove the three screws running along the back edge of case cover.
Remove the two screws from each side of the case cover.
Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
Locate the four screws securing the disk drive assembly. There are two on each side.
Use a narrow screwdriver to remove all four screws.
Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
2 other people completed this guide.
