Panasonic DVD-RV31 Player Right Function Board Replacement
  1. Panasonic DVD-RV31 Player Right Function Board Replacement, Disk Tray Cover: step 1, image 1 of 1
    • Eject the disk tray from the DVD player before removing power supply.
  2. Panasonic DVD-RV31 Player Right Function Board Replacement: step 2, image 1 of 1
    • Evenly lift upward on the disk tray front cover (not slanted, as pictured). This will allow for easier disassembly of the player.
  3. Panasonic DVD-RV31 Player Right Function Board Replacement, Outer Case: step 3, image 1 of 2 Panasonic DVD-RV31 Player Right Function Board Replacement, Outer Case: step 3, image 2 of 2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  4. Panasonic DVD-RV31 Player Right Function Board Replacement: step 4, image 1 of 1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  5. Panasonic DVD-RV31 Player Right Function Board Replacement, Front Panel: step 5, image 1 of 2 Panasonic DVD-RV31 Player Right Function Board Replacement, Front Panel: step 5, image 2 of 2
    • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
  6. Panasonic DVD-RV31 Player Right Function Board Replacement, Right Function Board: step 6, image 1 of 1
    • Remove 4 screws as shown.
  7. Panasonic DVD-RV31 Player Right Function Board Replacement: step 7, image 1 of 3 Panasonic DVD-RV31 Player Right Function Board Replacement: step 7, image 2 of 3 Panasonic DVD-RV31 Player Right Function Board Replacement: step 7, image 3 of 3
    • Push in plastic retainer tab on board.
    • Grasp edges of board and pull out.
Kevin
375 Reputation
8 Guides authored
Cal Poly, Team 18-20, Garner Spring 2011 Member of Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Members
11 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 2,131
