Panasonic ER-GN30-K Motor Replacement
  1. Panasonic ER-GN30-K Motor Replacement, Motor: step 1, image 1 of 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Replacement: step 2, image 1 of 1
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Replacement: step 3, image 1 of 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Replacement: step 4, image 1 of 1
    • Use a metal spudger to pry apart the silver plastic case.
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Replacement: step 5, image 1 of 1
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Replacement: step 6, image 1 of 1
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Replacement: step 7, image 1 of 2 Panasonic ER-GN30-K Motor Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
  8. Panasonic ER-GN30-K Motor Replacement: step 8, image 1 of 1
    • Remove the motor from the case by sliding the cover off of it.
6 other people completed this guide.
Corey Tappan
209 Reputation
1 Guide authored
USF Tampa, Team 15-3, Blackwell Fall 2015 Member of USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Members
5 Guides authored
One Comment
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Rocko the fixit cat - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 41
All Time: 3,561
