Panasonic ER-GN30-K Motor Shaft Replacement
  1. Panasonic ER-GN30-K Motor Shaft Replacement, Motor Shaft: step 1, image 1 of 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Shaft Replacement: step 2, image 1 of 1
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Shaft Replacement: step 3, image 1 of 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Shaft Replacement: step 4, image 1 of 1
    • The motor shaft should be sticking out from the top of the device.
    • Use the metal prying tool to pry apart the silver plastic case .
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Shaft Replacement: step 5, image 1 of 1
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Shaft Replacement: step 6, image 1 of 1
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Shaft Replacement: step 7, image 1 of 2 Panasonic ER-GN30-K Motor Shaft Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
Alejandro Garabatos
330 Reputation
2 Guides authored
USF Tampa, Team 15-3, Blackwell Fall 2015 Member of USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 Members
5 Guides authored
2 Comments
Thank you, small parts where switch is could be shown as well. Would be very helpful.
Advise for putting things back together: remove plastic switch cover and put back only after full reassembly
Aurimas Miko - Reply
Dear Alejandro,
thank You for your instruction, my question is where this motor shaft part is available? I can’t find it anywhere on the net. Thanks if you can help. Bence Fazekas
fazebence - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 19
All Time: 1,609
