Panasonic ES2207P Motor Replacement
  1. Panasonic ES2207P Motor Replacement, Battery: step 1, image 1 of 1
    • Remove foil head and blades.
  2. Panasonic ES2207P Motor Replacement: step 2, image 1 of 1
    • Remove (2) 7.9mm Phillips #0 screws.
    • Remove (2) 14.3mm Phillips #0 screws.
  3. Panasonic ES2207P Motor Replacement: step 3, image 1 of 1
    • Push the blade mount assembly towards the rear of razor and remove.
  4. Panasonic ES2207P Motor Replacement: step 4, image 1 of 1
    • Be careful not to break any tabs that hold the panels to the body.
    • Remove both external panels using spudger if necessary.
  5. Panasonic ES2207P Motor Replacement: step 5, image 1 of 1
  6. Panasonic ES2207P Motor Replacement: step 6, image 1 of 1
    • This step may require a fair amount of force due to the O-ring.
    • Pull to separate the end-cap from the body.
  7. Panasonic ES2207P Motor Replacement: step 7, image 1 of 1
    • Remove (2) 7.9mm Phillips #0 screws and remove endcap from frame.
  8. Panasonic ES2207P Motor Replacement: step 8, image 1 of 2 Panasonic ES2207P Motor Replacement: step 8, image 2 of 2
    • Push forward on the lower terminal to remove the battery from the frame.
  9. Panasonic ES2207P Motor Replacement, Motor: step 9, image 1 of 2 Panasonic ES2207P Motor Replacement, Motor: step 9, image 2 of 2
    • Remove battery contact.
  10. Panasonic ES2207P Motor Replacement: step 10, image 1 of 1
    • Using pointed end of spudger, push on the motor through the hole in the back
  11. Panasonic ES2207P Motor Replacement: step 11, image 1 of 1
    • Use your fingers to finish removing motor from frame.
Kevin Marvell
309 Reputation
2 Guides authored
IUPUI, Team S6-G5, Baechle Fall 2017 Member of IUPUI, Team S6-G5, Baechle Fall 2017
IUPUI-BAECHLE-F17S6G5
3 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 360
