Panasonic KX-E603 Printwheel Replacement
  1. Panasonic KX-E603 Printwheel Replacement, Ink Cartridge: step 1, image 1 of 2 Panasonic KX-E603 Printwheel Replacement, Ink Cartridge: step 1, image 2 of 2
    • Open the lid of the typewriter.
  2. Panasonic KX-E603 Printwheel Replacement: step 2, image 1 of 2 Panasonic KX-E603 Printwheel Replacement: step 2, image 2 of 2
    • To release the green locking lever, pull it towards you.
  3. Panasonic KX-E603 Printwheel Replacement: step 3, image 1 of 2 Panasonic KX-E603 Printwheel Replacement: step 3, image 2 of 2
    • Gently lift to remove the old ink cartridge.
  4. Panasonic KX-E603 Printwheel Replacement, Printwheel: step 4, image 1 of 2 Panasonic KX-E603 Printwheel Replacement, Printwheel: step 4, image 2 of 2
    • Firmly grasp either one, or both of the plastic printwheel ends protruding from the carriage as seen.
    • Gently lift the printwheel while slightly pushing forward to remove the printwheel from its housing.
To reassemble your device, follow these steps in reverse using your new printwheel.
Lindsay Stratis
491 Reputation
4 Guides authored
Cal Poly, Team 17-1, Forte Spring 2015 Member of Cal Poly, Team 17-1, Forte Spring 2015
CPSU-FORTE-S15S17G1
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 415
