Panasonic KX-T4000R Cordless Phone Antenna Replacement
  1. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Removing the Back Panel: step 1, image 1 of 2 Panasonic KX-T4000R Cordless Phone Antenna Replacement, Removing the Back Panel: step 1, image 2 of 2
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Panasonic KX-T4000R Cordless Phone Antenna Replacement: step 2, image 1 of 3 Panasonic KX-T4000R Cordless Phone Antenna Replacement: step 2, image 2 of 3 Panasonic KX-T4000R Cordless Phone Antenna Replacement: step 2, image 3 of 3
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. Panasonic KX-T4000R Cordless Phone Antenna Replacement, Antenna: step 3, image 1 of 2 Panasonic KX-T4000R Cordless Phone Antenna Replacement, Antenna: step 3, image 2 of 2
    • Find the silver screw located in the red circle.
    • Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
  4. Panasonic KX-T4000R Cordless Phone Antenna Replacement: step 4, image 1 of 2 Panasonic KX-T4000R Cordless Phone Antenna Replacement: step 4, image 2 of 2
    • Press the release button.
    • The release button is located in the red circle in the image to the left.
Elizabeth Kelly
501 Reputation
5 Guides authored
Clemson, Team 15-1, Benson Fall 2012 Member of Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 1,883
