Panasonic KX-TG6021M Button Pad Replacement
  1. Panasonic KX-TG6021M Button Pad Replacement, Battery: step 1, image 1 of 2 Panasonic KX-TG6021M Button Pad Replacement, Battery: step 1, image 2 of 2
    • Slide the back cover down towards the bottom of the phone to remove.
  2. Panasonic KX-TG6021M Button Pad Replacement: step 2, image 1 of 3 Panasonic KX-TG6021M Button Pad Replacement: step 2, image 2 of 3 Panasonic KX-TG6021M Button Pad Replacement: step 2, image 3 of 3
    • Pull the top of the battery towards you to remove it from the phone.
  3. Panasonic KX-TG6021M Button Pad Replacement, Front Panel: step 3, image 1 of 2 Panasonic KX-TG6021M Button Pad Replacement, Front Panel: step 3, image 2 of 2
    • Unscrew the two screws located at the bottom of the phone.
    • Use a PH00 Phillips head to remove the 9 mm screws.
  4. Panasonic KX-TG6021M Button Pad Replacement: step 4, image 1 of 3 Panasonic KX-TG6021M Button Pad Replacement: step 4, image 2 of 3 Panasonic KX-TG6021M Button Pad Replacement: step 4, image 3 of 3
    • Separate the back cover from the front cover by using a wedge.
    • Remove the back cover from the front cover by pulling them apart.
  5. Panasonic KX-TG6021M Button Pad Replacement: step 5, image 1 of 1
    • Remove three screws on the motherboard.
    • Pull the phone face off of the motherboard.
  6. Panasonic KX-TG6021M Button Pad Replacement, Button Pad: step 6, image 1 of 1
    • Remove the button pad.
2 other people completed this guide.
Leah Meador
328 Reputation
2 Guides authored
IUPUI, Team 3-1, Baechle Fall 2016 Member of IUPUI, Team 3-1, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G1
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 45
All Time: 991
