Panasonic KX-TGE233 TEL Port Replacement
  1. Panasonic KX-TGE233 TEL Port Replacement, Base Front Panel Assembly: step 1, image 1 of 1
    • To fix this component, we'll need to work with the main docking station. This is the one with the answering machine and the TEL line.
  2. Panasonic KX-TGE233 TEL Port Replacement: step 2, image 1 of 1
    • To start, we'll need to work with objects on the bottom of the device, so begin by flipping the device over.
  3. Panasonic KX-TGE233 TEL Port Replacement: step 3, image 1 of 1
    • To open the main docking station, you'll need to remove four 11 mm Philips #0 screws.
  4. Panasonic KX-TGE233 TEL Port Replacement: step 4, image 1 of 1
    • With the screws removed, you can use a spudger to aid in removing the back from the device.
    • Levering the back by the spudger may break the tool!
  5. Panasonic KX-TGE233 TEL Port Replacement: step 5, image 1 of 1
    • With the back removed, we now have direct access to all other components in the main docking station.
  6. Panasonic KX-TGE233 TEL Port Replacement, TEL Port: step 6, image 1 of 1
    • For easier access to its wires, you can easily remove the TEL port from its resting point in the device.
  7. Panasonic KX-TGE233 TEL Port Replacement: step 7, image 1 of 1
  8. Panasonic KX-TGE233 TEL Port Replacement: step 8, image 1 of 1
    • From here, you can remove the faulty port from the device. If the soldering step has been completed successfully, this should require minimal effort.
Jesse Satterwhite
682 Reputation
5 Guides authored
IUPUI, Team 2-2, Baechle Spring 2016 Member of IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 473
