Panasonic Lumix DMC-F7 Battery Replacement
  1. Panasonic Lumix DMC-F7 Battery Replacement, Battery: step 1, image 1 of 1
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Battery Replacement: step 2, image 1 of 1
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
Hormoz Tarevern
170 Reputation
1 Guide authored
Cal Poly, Team 7-35, Regan Winter 2011 Member of Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 2,338
