Panasonic Lumix DMC-FH20 Battery Replacement
  1. Panasonic Lumix DMC-FH20 Battery Replacement, Battery: step 1, image 1 of 3 Panasonic Lumix DMC-FH20 Battery Replacement, Battery: step 1, image 2 of 3 Panasonic Lumix DMC-FH20 Battery Replacement, Battery: step 1, image 3 of 3
    • On the bottom of the camera, move the gray switch that has the words "open" and "lock" above it to the open position. The case will open.
  2. Panasonic Lumix DMC-FH20 Battery Replacement: step 2, image 1 of 3 Panasonic Lumix DMC-FH20 Battery Replacement: step 2, image 2 of 3 Panasonic Lumix DMC-FH20 Battery Replacement: step 2, image 3 of 3
    • Once the case is open, there will be another switch on the right side of the battery. Push the switch to the right to release the battery. Now you can pull the battery out.
Arianna Boushell
626 Reputation
5 Guides authored
Cal Poly, Team 10-7, Banghart Winter 2017 Member of Cal Poly, Team 10-7, Banghart Winter 2017
CPSU-BANGHART-W17S10G7
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 25
All Time: 649
