Panasonic Lumix DMC-FH20 Circuit Board Replacement
  1. Panasonic Lumix DMC-FH20 Circuit Board Replacement, Circuit Board: step 1, image 1 of 3 Panasonic Lumix DMC-FH20 Circuit Board Replacement, Circuit Board: step 1, image 2 of 3 Panasonic Lumix DMC-FH20 Circuit Board Replacement, Circuit Board: step 1, image 3 of 3
    • Remove all screws (Phillips #000 head) from the sides and bottom of the camera.
  2. Panasonic Lumix DMC-FH20 Circuit Board Replacement: step 2, image 1 of 1
    • Remove the back panel. This might require some extra force. If you still can't get the panel off, try to use a plastic opening tool.
  3. Panasonic Lumix DMC-FH20 Circuit Board Replacement: step 3, image 1 of 2 Panasonic Lumix DMC-FH20 Circuit Board Replacement: step 3, image 2 of 2
    • Remove the circuit board. You should be able to do this with your fingers. Just grab it and pull upwards. If it does not come, use a plastic opening tool to help.
Arianna Boushell
626 Reputation
5 Guides authored
Cal Poly, Team 10-7, Banghart Winter 2017 Member of Cal Poly, Team 10-7, Banghart Winter 2017
CPSU-BANGHART-W17S10G7
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 356
