Panasonic Lumix DMC-FH25 Front Case Replacement
  1. Panasonic Lumix DMC-FH25 Front Case Replacement, Front Case: step 1, image 1 of 3 Panasonic Lumix DMC-FH25 Front Case Replacement, Front Case: step 1, image 2 of 3 Panasonic Lumix DMC-FH25 Front Case Replacement, Front Case: step 1, image 3 of 3
    • Remove four screws on the front case using a 00 Phillips head screwdriver. Two will be on the side with the camera strap, one on the bottom, and one on the side opposing the camera strap. They will be in pairs, one screw holding the front case and one screw holding the back case.
  2. Panasonic Lumix DMC-FH25 Front Case Replacement: step 2, image 1 of 1
    • Using a plastic opening tool and your hands, pull the front case loose from the camera.
  3. Panasonic Lumix DMC-FH25 Front Case Replacement: step 3, image 1 of 2 Panasonic Lumix DMC-FH25 Front Case Replacement: step 3, image 2 of 2
    • Remove the front case from the camera.
Janice Weldon
612 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 274
