Panasonic Lumix DMC-FH25 LCD Screen Replacement
  1. Panasonic Lumix DMC-FH25 LCD Screen Replacement, Back Case: step 1, image 1 of 3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, Back Case: step 1, image 2 of 3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, Back Case: step 1, image 3 of 3
    • Remove 5 screws attached to the back case using a 00 Phillips head screwdriver.
  2. Panasonic Lumix DMC-FH25 LCD Screen Replacement: step 2, image 1 of 1
    • Using your hands and a pry tool, lever the back case off.
  3. Panasonic Lumix DMC-FH25 LCD Screen Replacement: step 3, image 1 of 2 Panasonic Lumix DMC-FH25 LCD Screen Replacement: step 3, image 2 of 2
    • Remove the back case.
  4. Panasonic Lumix DMC-FH25 LCD Screen Replacement, LCD Screen: step 4, image 1 of 3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, LCD Screen: step 4, image 2 of 3 Panasonic Lumix DMC-FH25 LCD Screen Replacement, LCD Screen: step 4, image 3 of 3
    • Using a 00 Phillips head screwdriver, remove a screw from the top right corner of the screen.
    • Lift the screen, being careful not to tear the ribbon cables on the right side.
  5. Panasonic Lumix DMC-FH25 LCD Screen Replacement: step 5, image 1 of 2 Panasonic Lumix DMC-FH25 LCD Screen Replacement: step 5, image 2 of 2
    • Access the ribbon cables by removing the green button receiver panel using a plastic opening tool. There is a white panel beneath. Carefully remove this using a plastic opening tool. The white panel may require some elbow grease to get it off, and the panel may make a snapping sound as it comes off.
  6. Panasonic Lumix DMC-FH25 LCD Screen Replacement: step 6, image 1 of 2 Panasonic Lumix DMC-FH25 LCD Screen Replacement: step 6, image 2 of 2
    • One of the ribbon cables will be housed behind the screen and the other will be under the panels. Gently pull each free from the housing and remove the screen.
2 other people completed this guide.
Janice Weldon
612 Reputation
5 Guides authored
One Comment
it has been quite easy tank you for sharing your help serge jobin
Serge Jobin - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 529
