Panasonic Lumix DMC-FX01 Front Casing Replacement
Andrew
Andrew and 7 other contributors
Last updated on January 3, 2023
30 - 45 minutes
Difficult
Introduction
Go to step 1
Use this guide to replace the front casing of your Panasonic Lumix DMC-FX01.
Tools
  1. Panasonic Lumix DMC-FX01 Front Casing Replacement, Battery: step 1, image 1 of 1
    • Locate the memory card and battery card latch on the bottom of the camera.
    • Slide the latch to the open position.
  2. Panasonic Lumix DMC-FX01 Front Casing Replacement: step 2, image 1 of 1
    • Open the battery latch, and slide the battery release lever to the right.
  3. Panasonic Lumix DMC-FX01 Front Casing Replacement: step 3, image 1 of 1
    • Remove the battery from the camera.
  4. Panasonic Lumix DMC-FX01 Front Casing Replacement, Rear Casing: step 4, image 1 of 1
    • Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
  5. Panasonic Lumix DMC-FX01 Front Casing Replacement: step 5, image 1 of 1
    • Remove the single 3.2 mm screw on the left side of the camera using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-FX01 Front Casing Replacement: step 6, image 1 of 2 Panasonic Lumix DMC-FX01 Front Casing Replacement: step 6, image 2 of 2
    • Remove the left side casing.
  7. Panasonic Lumix DMC-FX01 Front Casing Replacement: step 7, image 1 of 1
    • Remove the two 3.2 mm screws on the right side of the camera using a Phillips #00 screwdriver.
  8. Panasonic Lumix DMC-FX01 Front Casing Replacement: step 8, image 1 of 1
    • Remove the bottom right panel.
  9. Panasonic Lumix DMC-FX01 Front Casing Replacement: step 9, image 1 of 2 Panasonic Lumix DMC-FX01 Front Casing Replacement: step 9, image 2 of 2
    • Gently remove the back casing.
    • Start at the bottom and carefully pry towards the top to get this piece free.
  10. Panasonic Lumix DMC-FX01 Front Casing Replacement, LCD Screen: step 10, image 1 of 1
    • Gently lift up the LCD screen.
    • Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
    • It should fall out on its own or with a gentle tug.
  11. Panasonic Lumix DMC-FX01 Front Casing Replacement: step 11, image 1 of 1
    • Gently tug the thicker ribbon to remove it from its housing.
  12. Panasonic Lumix DMC-FX01 Front Casing Replacement, Front Casing: step 12, image 1 of 2 Panasonic Lumix DMC-FX01 Front Casing Replacement, Front Casing: step 12, image 2 of 2
    • Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
    • There may be a third screw the the right of the lens assembly.
  13. Panasonic Lumix DMC-FX01 Front Casing Replacement: step 13, image 1 of 3 Panasonic Lumix DMC-FX01 Front Casing Replacement: step 13, image 2 of 3 Panasonic Lumix DMC-FX01 Front Casing Replacement: step 13, image 3 of 3
    • Carefully remove the upper assembly, which houses the buttons and the flash battery.
  14. Panasonic Lumix DMC-FX01 Front Casing Replacement: step 14, image 1 of 1
    • Carefully remove the front casing after verifying that the thin plastic around the lens is not still attached.
2 other people completed this guide.
Andrew
396 Reputation
4 Guides authored
Cal Poly, Team 9-22, Regan Fall 2010 Member of Cal Poly, Team 9-22, Regan Fall 2010
CPSU-REGAN-F10S9G22
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 4,342
