Panasonic Lumix DMC-FX01 Lens Assembly Replacement
Introduction
Go to step 1This guide will be useful for anyone who wants to replace a broken or damaged Panasonic Lumix DMC-FX01 lens assembly.
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Remove the three 4.6 mm screws on the bottom of the camera using a Phillips #00 screwdriver.
Gently lift up the LCD screen.
Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
It should fall out on its own or with a gentle tug.
Remove the two black 5.4 mm screws that hold in the front faceplate using a Phillips #00 screwdriver.
5 other people completed this guide.
