Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement
  1. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement, Loose Digitizer Cable: step 1, image 1 of 1
    • Power off your device by locating the on/off switch on top of camera.
  2. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: step 2, image 1 of 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: step 2, image 2 of 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: step 2, image 3 of 3
    • Remove the screw located on the right side of the camera.
    • Remove the screw located on the bottom right of the camera, and remove the cover from the camera.
  3. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: step 3, image 1 of 1
    • Remove the screw located on the base of the camera.
  4. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: step 4, image 1 of 1
    • Pry the top part of the camera slowly. Be careful not to tear the digitilizer cable.
  5. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: step 5, image 1 of 2 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: step 5, image 2 of 2
    • Open the bigger clamp using a spudger or other tools. Repeat for the smaller clamp.
  6. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: step 6, image 1 of 2 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: step 6, image 2 of 2
    • Carefully take the thin ribbon and insert cable end into the latch. Do this for both sides.
  7. Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: step 7, image 1 of 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: step 7, image 2 of 3 Panasonic Lumix DMC-FX9 Loose Digitizer Cable Replacement: step 7, image 3 of 3
    • Once the ribbon is placed into the latch, carefully close the clamps by lowering the clamp into a down position. Repeat this step for both sides.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 344
