Panasonic Lumix DMC-FX9 Selector Buttons Replacement
  1. Panasonic Lumix DMC-FX9 Selector Buttons Replacement, Selector Buttons: step 1, image 1 of 1
    • Make sure the power is off by switching the power switch to the left.
  2. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the screws on the left side of the camera.
  3. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: step 3, image 1 of 1
    • Remove the screws on the right side of the camera by using the Philips #00 screwdriver.
  4. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: step 4, image 1 of 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: step 4, image 2 of 2
    • Remove the screws on the bottom side of the camera using the Philips #00 Screwdriver.
    • Separate the covers by gently applying force upwards, carefully placing the opening tool between the two covers.
  5. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: step 5, image 1 of 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: step 5, image 2 of 2
    • Lift the ZIF tabs up with the opening tool and carefully remove the digitizer ribbon cables.
    • Remove the LCD Screen from the glass frame carefully with the opening tool.
  6. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: step 6, image 1 of 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: step 6, image 2 of 2
    • Push on the back panel buttons on the front side to remove the buttons.
    • Be cautious of the adhesive holding the button panels to the cover. Apply extra force if necessary.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 290
