Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement
  1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: step 1, image 1 of 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: step 1, image 2 of 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: step 1, image 3 of 3
    • Remove the four 4.6mm J000 Phillips screws from the sides and two 3.2mm J000 Phillips screws along the bottom.
  2. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: step 2, image 1 of 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: step 2, image 2 of 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: step 2, image 3 of 3
    • Remove the two 3.2mm J000 Phillips screws located on the bottom edge of the viewfinder cover.
    • Carefully remove the viewfinder cover.
    • Remove the two 4.4mm J000 Phillips screws located near the top edge of the viewfinder.
  3. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: step 3, image 1 of 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: step 3, image 2 of 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: step 3, image 3 of 3
    • Slide the Wide Plastic Opening Tool upwards along the underside of the rear casing.
    • Be careful not to disconnect the filament connections. Reinserting them can be difficult.
    • Slowly lower the casing into the position shown.
  4. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: step 4, image 1 of 2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: step 4, image 2 of 2
    • Use the Screwdriver J000 Phillips Head to remove the screw located at the lower-left corner of the face of the viewfinder glass.
    • Carefully lift the L-shaped clicker underneath the previously removed screw.
  5. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: step 5, image 1 of 2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: step 5, image 2 of 2
    • Slide the faulty diopter adjustment dial off the rod.
    • Replace the diopter dial with a 1-cm wheel.
Gabriel Gonzalez Jr
325 Reputation
3 Guides authored
USF Tampa, Team 1-3, Kass Spring 2017 Member of USF Tampa, Team 1-3, Kass Spring 2017
USFT-KASS-S17S1G3
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 23
All Time: 1,058
