Panasonic Lumix DMC-G5 Motherboard Replacement
  1. Panasonic Lumix DMC-G5 Motherboard Replacement, Back Panel: step 1, image 1 of 1
    • Remove four JIS #000 screws from the bottom part of the camera.
  2. Panasonic Lumix DMC-G5 Motherboard Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-G5 Motherboard Replacement: step 2, image 2 of 2
    • Remove two JIS #000 screws from both sides of the camera.
  3. Panasonic Lumix DMC-G5 Motherboard Replacement: step 3, image 1 of 1
    • Remove two JIS #000 screws under the viewfinder.
  4. Panasonic Lumix DMC-G5 Motherboard Replacement: step 4, image 1 of 2 Panasonic Lumix DMC-G5 Motherboard Replacement: step 4, image 2 of 2
    • Remove the viewfinder lid.
    • Then, remove the two JIS #000 screws on the viewfinder.
  5. Panasonic Lumix DMC-G5 Motherboard Replacement: step 5, image 1 of 3 Panasonic Lumix DMC-G5 Motherboard Replacement: step 5, image 2 of 3 Panasonic Lumix DMC-G5 Motherboard Replacement: step 5, image 3 of 3
    • Gently remove the back panel from the camera.
    • Unclip the ribbon cable from the motherboard using Wide Plastic Opening Tools and pull the cable gently.
  6. Panasonic Lumix DMC-G5 Motherboard Replacement, Motherboard: step 6, image 1 of 1
    • Remove the JIS #000 screws on the motherboard.
  7. Panasonic Lumix DMC-G5 Motherboard Replacement: step 7, image 1 of 2 Panasonic Lumix DMC-G5 Motherboard Replacement: step 7, image 2 of 2
    • Unclip the ribbon cable using the Wide Plastic Opening Tool on the motherboard.
    • Gently pull out the cable.
  8. Panasonic Lumix DMC-G5 Motherboard Replacement: step 8, image 1 of 1
    • Pull out the motherboard from the camera.
Khairul Samsudin
412 Reputation
4 Guides authored
IUPUI, Team S1-G4, Harley Summer 2019 Member of IUPUI, Team S1-G4, Harley Summer 2019
IUPUI-HARLEY-SU19S1G4
3 Members
8 Guides authored
One Comment
Dear Khairul Samsudin - this is great, thank you so much.
Can I ask about another classic repair for the Lumix G5?
As with many lumix cameras, the rear thumbwheel on the Lumix G5 is a weak point and frequently fails - usually the “push in” movement that should change functions failes in the “pushed in” position.
Plese can you see if you can create a “fix” for this? It classically fails at about year 2-3, when the camera is out of warranty and the repairs cost from Panasonic is more than a secondhand G5 on eBay will cost!
Best wishes - Paul in the UK
Paul C - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,414
