Panasonic Lumix DMC-GF2 Back Cover Replacement
  1. Panasonic Lumix DMC-GF2 Back Cover Replacement, Battery: step 1, image 1 of 1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-GF2 Back Cover Replacement: step 2, image 2 of 2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: step 3, image 1 of 3 Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: step 3, image 2 of 3 Panasonic Lumix DMC-GF2 Back Cover Replacement, Back Cover: step 3, image 3 of 3
    • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
  4. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 4, image 1 of 3 Panasonic Lumix DMC-GF2 Back Cover Replacement: step 4, image 2 of 3 Panasonic Lumix DMC-GF2 Back Cover Replacement: step 4, image 3 of 3
    • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
    • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
    • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
  5. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 5, image 1 of 1
    • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
  6. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 6, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
  7. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 7, image 1 of 1
    • Using a spudger, lift up and remove the plastic cover piece from the back cover.
    • Plastic cover may fall off without prying.
  8. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 8, image 1 of 1
    • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
  9. Panasonic Lumix DMC-GF2 Back Cover Replacement: step 9, image 1 of 1
    • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
    • Metal cover may fall off without prying.
Kingsley East
462 Reputation
4 Guides authored
Baylor, Team 5-9, Williams Fall 2016 Member of Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
3 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 1,079
