Panasonic Lumix DMC-GF2 Front Cover Replacement
  1. Panasonic Lumix DMC-GF2 Front Cover Replacement, Battery: step 1, image 1 of 1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Front Cover Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-GF2 Front Cover Replacement: step 2, image 2 of 2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: step 3, image 1 of 3 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: step 3, image 2 of 3 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: step 3, image 3 of 3
    • Using a Philips #00 screwdriver, remove six 2.69 mm screws located on the two short sides and on the bottom of the camera.
    • To loosen a screw, turn the screwdriver to the left. To tighten a screw, turn the screwdriver to the right.
  4. Panasonic Lumix DMC-GF2 Front Cover Replacement: step 4, image 1 of 1
    • Using a Phillips #00 screwdriver, remove four black 2.69 mm screws from the front of the camera.
  5. Panasonic Lumix DMC-GF2 Front Cover Replacement: step 5, image 1 of 1
    • Using your hand, gently lift up the front cover and separate it from the camera.
Nicole Gerlach
218 Reputation
1 Guide authored
Baylor, Team 5-9, Williams Fall 2016 Member of Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
3 Members
11 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,039
