Panasonic Lumix DMC-ZS25 Screen Replacement
  1. Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: step 1, image 1 of 3 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: step 1, image 2 of 3 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: step 1, image 3 of 3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Screen Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to open the outer cover of your device from the HDMI port.
    • Open it carefully to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Screen Replacement: step 3, image 1 of 3 Panasonic Lumix DMC-ZS25  Screen Replacement: step 3, image 2 of 3 Panasonic Lumix DMC-ZS25  Screen Replacement: step 3, image 3 of 3
    • Use a spudger to carefully detach the ribbon cable without breaking it.
  4. Panasonic Lumix DMC-ZS25  Screen Replacement: step 4, image 1 of 1
    • Use the plastic opening tool to lift and remove the buttons board as shown.
  5. Panasonic Lumix DMC-ZS25  Screen Replacement: step 5, image 1 of 2 Panasonic Lumix DMC-ZS25  Screen Replacement: step 5, image 2 of 2
    • Carefully lift the screen using the plastic opening tool as shown.
3 other people completed this guide.
Abbas Khan
482 Reputation
4 Guides authored
USF Tampa, Team 9-5, Brown Winter 2015 Member of USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 Members
7 Guides authored
One Comment
- Of the two 2.60 mm screws on the bottom of the camera, only the one closest to the back needs to be removed.
- The correct screwdriver is JIS Type S #00. A Phillips driver can ruin the screws.
- The screen shown in step 5 consists of two parts: the LCD and a frame. The replacement LCD that I ordered came without the frame, so a little more disassembly was required, including a bit of delicate soldering: the narrow ribbon cable is really two cables, soldered together. The solder joints are hidden under the piece of black electric tape at the end.
nasorenga - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 12
All Time: 4,406
