Panasonic Lumix DMC-ZS25 Flash Replacement
  1. Panasonic Lumix DMC-ZS25 Flash Replacement, Flash: step 1, image 1 of 2 Panasonic Lumix DMC-ZS25 Flash Replacement, Flash: step 1, image 2 of 2
    • Using a small screwdriver, remove the four 3.4mm screws from the right and left sides of your Panasonic Lumix Camera.
  2. Panasonic Lumix DMC-ZS25 Flash Replacement: step 2, image 1 of 1
    • Using a small screwdriver, remove the two 2.6mm screws located next to the battery, on the outer casing.
  3. Panasonic Lumix DMC-ZS25 Flash Replacement: step 3, image 1 of 1
    • Using the plastic opening tool, open the outer cover of your device.
    • The easiest way to open your device is by placing the tool in the HDMI port.
  4. Panasonic Lumix DMC-ZS25 Flash Replacement: step 4, image 1 of 3 Panasonic Lumix DMC-ZS25 Flash Replacement: step 4, image 2 of 3 Panasonic Lumix DMC-ZS25 Flash Replacement: step 4, image 3 of 3
    • Using the spudger, pull upward on the screen cable to release it.
  5. Panasonic Lumix DMC-ZS25 Flash Replacement: step 5, image 1 of 1
    • Using the plastic opening tool, lift the button board until it clicks.
  6. Panasonic Lumix DMC-ZS25 Flash Replacement: step 6, image 1 of 2 Panasonic Lumix DMC-ZS25 Flash Replacement: step 6, image 2 of 2
    • Using the plastic opening tool, lift the screen until it clicks.
  7. Panasonic Lumix DMC-ZS25 Flash Replacement: step 7, image 1 of 1
    • Using a small screwdriver, remove the two 4.2mm screws located on the corner of the inner cover, under the screen.
  8. Panasonic Lumix DMC-ZS25 Flash Replacement: step 8, image 1 of 1
    • Using the plastic opening tool, remove the inner cover.
  9. Panasonic Lumix DMC-ZS25 Flash Replacement: step 9, image 1 of 2 Panasonic Lumix DMC-ZS25 Flash Replacement: step 9, image 2 of 2
    • Using your hands or the opening tool, separate the device into two pieces, as shown.
  10. Panasonic Lumix DMC-ZS25 Flash Replacement: step 10, image 1 of 2 Panasonic Lumix DMC-ZS25 Flash Replacement: step 10, image 2 of 2
    • Using the spudger, remove the black side cover.
  11. Panasonic Lumix DMC-ZS25 Flash Replacement: step 11, image 1 of 1
    • Using your hands, remove the front cover.
  12. Panasonic Lumix DMC-ZS25 Flash Replacement: step 12, image 1 of 3 Panasonic Lumix DMC-ZS25 Flash Replacement: step 12, image 2 of 3 Panasonic Lumix DMC-ZS25 Flash Replacement: step 12, image 3 of 3
    • Using the spudger, unlock the screen cables from the circuit board.
    • Lift up the black clip to release the cables.
  13. Panasonic Lumix DMC-ZS25 Flash Replacement: step 13, image 1 of 1
    • Using your hands, remove the lens.
  14. Panasonic Lumix DMC-ZS25 Flash Replacement: step 14, image 1 of 1
    • Using the plastic opening tool, pull up on the edge of the circuit board until it clicks.
    • Remove the board.
  15. Panasonic Lumix DMC-ZS25 Flash Replacement: step 15, image 1 of 1
    • Using a small screwdriver, remove the 3.7 mm screw near the green chip inside the camera, as shown. This will release the top of the camera.
  16. Panasonic Lumix DMC-ZS25 Flash Replacement: step 16, image 1 of 3 Panasonic Lumix DMC-ZS25 Flash Replacement: step 16, image 2 of 3 Panasonic Lumix DMC-ZS25 Flash Replacement: step 16, image 3 of 3
    • Using the opening tool, pull up on the edge of the top cover to unlock it.
  17. Panasonic Lumix DMC-ZS25 Flash Replacement: step 17, image 1 of 2 Panasonic Lumix DMC-ZS25 Flash Replacement: step 17, image 2 of 2
    • Using the opening tool, remove the top board.
  18. Panasonic Lumix DMC-ZS25 Flash Replacement: step 18, image 1 of 2 Panasonic Lumix DMC-ZS25 Flash Replacement: step 18, image 2 of 2
    • Place the tip of the spudger at the edge of the top board, and work around three sides to loosen it.
    • Using the opening tool, lift up the top board. Now you will be able to safely remove the flash.
  19. Panasonic Lumix DMC-ZS25 Flash Replacement: step 20, image 1 of 1
    • Remove the old flash, and put in the replacement.
Abbas Khan
482 Reputation
4 Guides authored
USF Tampa, Team 9-5, Brown Winter 2015 Member of USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 454
