Panasonic Lumix DMC-ZS3 Back panel buttons Replacement
  1. Panasonic Lumix DMC-ZS3 Back panel buttons Replacement, Back Cover: step 1, image 1 of 3 Panasonic Lumix DMC-ZS3 Back panel buttons Replacement, Back Cover: step 1, image 2 of 3 Panasonic Lumix DMC-ZS3 Back panel buttons Replacement, Back Cover: step 1, image 3 of 3
    • Remove the following eleven screws securing the covers to the ZS3
    • Eleven 3 mm Phillips screws
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Panasonic Lumix DMC-ZS3 Back panel buttons Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-ZS3 Back panel buttons Replacement: step 2, image 2 of 2
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
  3. Panasonic Lumix DMC-ZS3 Back panel buttons Replacement: step 3, image 1 of 2 Panasonic Lumix DMC-ZS3 Back panel buttons Replacement: step 3, image 2 of 2
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
  4. Panasonic Lumix DMC-ZS3 Back panel buttons Replacement: step 4, image 1 of 1
    • Remove the two LCD board ribbon cables out of their sockets.
  5. Panasonic Lumix DMC-ZS3 Back panel buttons Replacement, Back panel buttons: step 5, image 1 of 3 Panasonic Lumix DMC-ZS3 Back panel buttons Replacement, Back panel buttons: step 5, image 2 of 3 Panasonic Lumix DMC-ZS3 Back panel buttons Replacement, Back panel buttons: step 5, image 3 of 3
    • Use the flat end of the spudger to gently pry the buttons from the back panel.
    • Remove the buttons in three pieces, starting with the top left one, then moving to one next to it. Once this is finished remove the rest of the buttons.
    • The buttons are attached to the back cover using adhesive, and this may need to be reapplied to put them back on.
Cal Poly, Team 13-60, Johann Spring 2013 Member of Cal Poly, Team 13-60, Johann Spring 2013
CPSU-JOHANN-S13S13G60
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 526
