Panasonic Lumix DMC-ZS3 Battery Replacement
  1. Panasonic Lumix DMC-ZS3 Battery Replacement, Battery: step 1, image 1 of 1
    • Locate the small, hinged door on the bottom of the camera.
  2. Panasonic Lumix DMC-ZS3 Battery Replacement: step 2, image 1 of 1
    • Using your fingernail or a spudger, push the small, grey switch on the hinged door from the left (locked) to the right (unlocked).
    • The hinged door should swing open after unlocking.
  3. Panasonic Lumix DMC-ZS3 Battery Replacement: step 3, image 1 of 1
    • Using your fingernail or a spudger, push down on the small, grey tab holding the battery in place.
    • This should release the battery.
  4. Panasonic Lumix DMC-ZS3 Battery Replacement: step 4, image 1 of 2 Panasonic Lumix DMC-ZS3 Battery Replacement: step 4, image 2 of 2
    • Pull the battery out of the camera.
    • The battery should slide out easily.
Cal Poly, Team 13-60, Johann Spring 2013 Member of Cal Poly, Team 13-60, Johann Spring 2013
CPSU-JOHANN-S13S13G60
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 23
All Time: 1,280
