Panasonic Lumix DMC-ZS40 Battery Replacement
  1. Panasonic Lumix DMC-ZS40 Battery Replacement, Battery: step 1, image 1 of 2 Panasonic Lumix DMC-ZS40 Battery Replacement, Battery: step 1, image 2 of 2
    • Find the battery/memory card door on the bottom right of the camera.
    • Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
  2. Panasonic Lumix DMC-ZS40 Battery Replacement: step 2, image 1 of 1
    • Push up on the right-hand-side tab to release the battery.
  3. Panasonic Lumix DMC-ZS40 Battery Replacement: step 3, image 1 of 2 Panasonic Lumix DMC-ZS40 Battery Replacement: step 3, image 2 of 2
    • Remove battery from camera.
Follow these instructions in reverse order to replace the battery and reassemble.
Dean Favetta
340 Reputation
3 Guides authored
USF Tampa, Team 20-3, Remmell Spring 2017 Member of USF Tampa, Team 20-3, Remmell Spring 2017
USFT-REMMELL-S17S20G3
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 29
All Time: 1,191
