Panasonic Lumix DMC-ZS6 SD Card Reader Replacement
  1. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement, SD Card Reader: step 1, image 1 of 1
    • Remove the battery and the SD card.
  2. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 2, image 1 of 3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 2, image 2 of 3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 2, image 3 of 3
    • Unscrew the bottom two 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws on the right with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws on the left with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 3, image 1 of 1
    • Carefully separate the back of the camera from the main body.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 4, image 1 of 2 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 4, image 2 of 2
    • Use the tip of the spudger to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 5, image 1 of 3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 5, image 2 of 3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 5, image 3 of 3
    • Unscrew the bottom 1.0 mm screw with a Phillips #000 screwdriver.
  6. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 6, image 1 of 1
    • Separate the front of the camera from the main body.
  7. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 7, image 1 of 2 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 7, image 2 of 2
    • Use the tip of the spudger to disengage the plastic tab.
    • Carefully lift the selector switch away from the motherboard.
  8. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 8, image 1 of 2 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 8, image 2 of 2
    • Unscrew the three silver 1.0 mm screws with a Phillips #000 screwdriver.
    • Use the tip of the spudger to disengage the metal tab.
    • Carefully lift the shield away from the motherboard.
  9. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 9, image 1 of 1
    • Insert the tip of the spudger into the center hole of the tripod mount.
    • Apply force in the direction facing away from the button.
    • Carefully lift the tripod mount out of the camera body.
  10. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 10, image 1 of 2 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 10, image 2 of 2
    • Use the spudger to flip up the brown tab on the motherboard and carefully unseat the ribbon cable.
    • Insert the tip of the spudger into the hole on the daughterboard.
    • Apply upward force to remove the daughterboard from the main case.
  11. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 11, image 1 of 3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 11, image 2 of 3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 11, image 3 of 3
    • Use the spudger to flip up the two tabs on the motherboard and carefully unseat the ribbon cables.
    • Use the Phillips #000 screwdriver to remove the three 1.0 mm silver screws.
    • Carefully lift the lens assembly out of the camera.
  12. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 12, image 1 of 3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 12, image 2 of 3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 12, image 3 of 3
    • Use the tip of the spudger to disengage the tab on the back of the camera.
    • Use the tip of the spudger to disengage the two tabs on the front of the camera.
    • Carefully lift the top assembly out of place.
  13. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 13, image 1 of 2 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 13, image 2 of 2
    • Use the spudger to disengage the two tabs.
    • Carefully lift the flash assembly out of place.
  14. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 14, image 1 of 3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 14, image 2 of 3 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 14, image 3 of 3
    • Use the tip of the spudger to flip up the tab to unseat the ribbon cable.
    • Unscrew the two silver 1.0 mm screws with a Phillips #000.
    • Use the tip of the spudger to disengage the two plastic tabs, and carefully lift the motherboard out of place.
  15. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 15, image 1 of 2 Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 15, image 2 of 2
    • Unscrew the one silver 1.0 mm screw with a Phillips #000 screwdriver.
    • Use to tip of the spudger to disengage the plastic tab, then carefully lift the plastic shield out of place.
  16. Panasonic Lumix DMC-ZS6 SD Card Reader Replacement: step 16, image 1 of 1
    • Carefully lift the SD card reader assembly out of place.
Derrick Thompson
1,035 Reputation
5 Guides authored
Baylor, Team S2-G5, Johnson Spring 2018 Member of Baylor, Team S2-G5, Johnson Spring 2018
BU-JOHNSON-S18S2G5
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 1,310
