Panasonic Lumix DMC-ZS60 LCD Screen Replacement
  1. Panasonic Lumix DMC-ZS60 LCD Screen Replacement, Battery: step 1, image 1 of 1
    • Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
  2. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: step 2, image 2 of 2
    • Push up the black tab on the right-hand-side to spring release the battery.
  3. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: step 3, image 1 of 1
    • Remove the battery by sliding it out from the camera.
  4. Panasonic Lumix DMC-ZS60 LCD Screen Replacement, LCD Screen: step 4, image 1 of 3 Panasonic Lumix DMC-ZS60 LCD Screen Replacement, LCD Screen: step 4, image 2 of 3 Panasonic Lumix DMC-ZS60 LCD Screen Replacement, LCD Screen: step 4, image 3 of 3
    • Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
  5. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: step 5, image 1 of 1
    • Pry off back casing and set aside.
  6. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: step 6, image 1 of 2 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Pull the right side control dial circuit board up.
    • Use tweezers to pry up the white retaining flap and gently pull the circuit board out.
  7. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: step 7, image 1 of 3 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: step 7, image 2 of 3 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: step 7, image 3 of 3
    • Flip the LCD screen to the left.
    • Unscrew the two 3mm on the top right side using the Phillips #000 Screwdriver.
    • Lift the gray plate cover off.
  8. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: step 8, image 1 of 2 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: step 8, image 2 of 2
    • Use tweezers to pry up the black retaining flat and gently pull to free the LCD screen from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 440
