Panasonic Lumix DMC-ZS60 Motherboard Replacement
  1. Panasonic Lumix DMC-ZS60 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
  2. Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 2, image 1 of 2 Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 2, image 2 of 2
    • Push up the black tab on the right-hand-side to spring release the battery.
  3. Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 3, image 1 of 1
    • Remove the battery by sliding it out from the camera.
  4. Panasonic Lumix DMC-ZS60 Motherboard Replacement, LCD Screen: step 4, image 1 of 3 Panasonic Lumix DMC-ZS60 Motherboard Replacement, LCD Screen: step 4, image 2 of 3 Panasonic Lumix DMC-ZS60 Motherboard Replacement, LCD Screen: step 4, image 3 of 3
    • Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
  5. Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 5, image 1 of 1
    • Pry off back casing and set aside.
  6. Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 6, image 1 of 2 Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Pull the right side control dial circuit board up.
    • Use tweezers to pry up the white retaining flap and gently pull the circuit board out.
  7. Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 7, image 1 of 3 Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 7, image 2 of 3 Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 7, image 3 of 3
    • Flip the LCD screen to the left.
    • Unscrew the two 3mm on the top right side using the Phillips #000 Screwdriver.
    • Lift the gray plate cover off.
  8. Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 8, image 1 of 2 Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 8, image 2 of 2
    • Use tweezers to pry up the black retaining flat and gently pull to free the LCD screen from the device.
  9. Panasonic Lumix DMC-ZS60 Motherboard Replacement, Motherboard: step 9, image 1 of 1
    • Remove these three 3 mm screws with a Phillips #000 screwdriver.
  10. Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 10, image 1 of 3 Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 10, image 2 of 3 Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 10, image 3 of 3
    Buy
    • Disconnect these 9 ribbon cables from the motherboard. One ribbon cable is hidden underneath the larger one on the left.
    • Use tweezers to first lift up the retaining flaps for each connector, then pull out the ribbon cable.
  11. Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 11, image 1 of 2 Panasonic Lumix DMC-ZS60 Motherboard Replacement: step 11, image 2 of 2
    • Now you will able to lift the motherboard up and it will only be connected by two cables.
    • To fully remove the motherboard, you will have to solder the metal in order to remove the wires.
    • For more information on soldering, please visit the How to Solder and Desolder Connections guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 421
