Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement
  1. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: step 1, image 1 of 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: step 1, image 2 of 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: step 1, image 3 of 3
    • Remove the side panels by unscrewing the Phillips head screws on both sides of the camera.
  2. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: step 2, image 1 of 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: step 2, image 2 of 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: step 2, image 3 of 3
    • Remove the back panel by unscrewing the two Phillips head screws on the bottom of the camera towards the back.
    • Lift the back panel from the camera and set it aside.
  3. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: step 3, image 1 of 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: step 3, image 2 of 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: step 3, image 3 of 3
    • Unscrew the Phillips head screw shown in the picture to remove the front panel.
    • Remove the front panel to expose the bracket at the bottom of the camera.
  4. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: step 4, image 1 of 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: step 4, image 2 of 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Pry the right side of the bracket up to allow you to grab the bracket with tweezers.
    • Grab the bracket with tweezers and slide it toward the battery door to remove it from the frame of the camera.
Trevor Meyers
356 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 325
