Panasonic Lumix ZS50 Battery Replacement
  1. Panasonic Lumix ZS50 Battery Replacement, Battery: step 1, image 1 of 2 Panasonic Lumix ZS50 Battery Replacement, Battery: step 1, image 2 of 2
    • Turn the camera off and identify the battery door located on the bottom of the camera.
  2. Panasonic Lumix ZS50 Battery Replacement: step 2, image 1 of 2 Panasonic Lumix ZS50 Battery Replacement: step 2, image 2 of 2
    • Slide the "open" latch to the left: the battery door should spring open.
    • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
  3. Panasonic Lumix ZS50 Battery Replacement: step 3, image 1 of 1
    • To release the battery, slide the white release lever next to the SD card slot.
    • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
  4. Panasonic Lumix ZS50 Battery Replacement: step 4, image 1 of 1
    • The battery should now be released; you may now remove the battery from the camera body.
Cameron Voos
32 Reputation
1 Guide authored
Baylor, Team 8-5, Whitney Spring 2017 Member of Baylor, Team 8-5, Whitney Spring 2017
BU-WHITNEY-S17S8G5
3 Members
7 Guides authored
One Comment
Repair guide is very clear and well-done
BayleeVersteeg - Reply
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 25
All Time: 530
