Panasonic RQ-2102 Holding Handle Replacement
  1. Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: step 1, image 1 of 3 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: step 1, image 2 of 3 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: step 1, image 3 of 3
    • Remove the three M5-0.8 x 12 mm Phillips #0 screws from the back of the device body.
    • There are two more screws inside the battery compartment. Remove those as well.
    • Cautiously remove the back of the device body. Be sure not to damage the cord that connects the two sides.
    • All of the screws are the same size.
  2. Panasonic RQ-2102 Holding Handle Replacement: step 2, image 1 of 2 Panasonic RQ-2102 Holding Handle Replacement: step 2, image 2 of 2
    • Carefully remove the handle. Make sure the handle catches on each side are intact.
    • Replace the old handle with the new handle.
    • Remember, if the handle catches are broken, the device must be replaced.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 588
