Panasonic SDR-H85 LCD Replacement
  1. Panasonic SDR-H85 LCD Replacement, Battery: step 1, image 1 of 3 Panasonic SDR-H85 LCD Replacement, Battery: step 1, image 2 of 3 Panasonic SDR-H85 LCD Replacement, Battery: step 1, image 3 of 3
    • Gently slide the battery ejection button which is located underneath the battery and slide the battery out.
    • Once the battery is removed, you can safely dispose it and replace with a new one. Dispose battery at an authorized battery recycling center.
  2. Panasonic SDR-H85 LCD Replacement, LCD Screen: step 2, image 1 of 2 Panasonic SDR-H85 LCD Replacement, LCD Screen: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove two screws from behind the corners of the display screen.
  3. Panasonic SDR-H85 LCD Replacement: step 3, image 1 of 2 Panasonic SDR-H85 LCD Replacement: step 3, image 2 of 2
    • Open the case carefully. Make sure to disconnect the parts.
  4. Panasonic SDR-H85 LCD Replacement: step 4, image 1 of 1
    • Use a Phillips #00 screwdriver to remove one screw on the green panel.
  5. Panasonic SDR-H85 LCD Replacement: step 5, image 1 of 3 Panasonic SDR-H85 LCD Replacement: step 5, image 2 of 3 Panasonic SDR-H85 LCD Replacement: step 5, image 3 of 3
    • Disconnect the panel from the screen part.
Ying Liu
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 14
All Time: 424
