Panasonic Toughbook CF-53 Optical Drive Replacement
  1. Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: step 1, image 1 of 2 Panasonic Toughbook CF-53 Optical Drive Replacement, Optical Drive: step 1, image 2 of 2
    • Orient the laptop onto its top and face the bottom towards you.
    • Remove the 3 mm Phillips #00 screws securing the Wi-Fi card/optical drive plastic cover.
  2. Panasonic Toughbook CF-53 Optical Drive Replacement: step 2, image 1 of 1
    • Remove the 5 mm Phillips #00 screw on the silver tab to the left.
  3. Panasonic Toughbook CF-53 Optical Drive Replacement: step 3, image 1 of 1
    • Reach under the silver tab and push the optical drive out of the side of the device using a spudger.
  4. Panasonic Toughbook CF-53 Optical Drive Replacement: step 4, image 1 of 1
    • Now that the drive is completely disconnected from the device, slide the optical drive out of its slot.
    • The end of the drive may seem to be stuck inside the device during removal. If this is the case gently wiggle the drive side to side and apply a small force until it pops free.
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 27
All Time: 1,605
