Panasonic Toughbook CF-53 Wi-Fi Card Replacement
  1. Panasonic Toughbook CF-53 Wi-Fi Card Replacement, Wi-Fi & Bluetooth Card: step 1, image 1 of 3 Panasonic Toughbook CF-53 Wi-Fi Card Replacement, Wi-Fi & Bluetooth Card: step 1, image 2 of 3 Panasonic Toughbook CF-53 Wi-Fi Card Replacement, Wi-Fi & Bluetooth Card: step 1, image 3 of 3
    • Turn the laptop to its back side and align it so that the handle is facing away from you.
    • Remove the single 4 mm Phillips #00 screw from the Wi-Fi card/optical drive cover and remove the plastic cover.
    • The Wi-Fi card is located closest to you , below the little strip-sized circuit board.
  2. Panasonic Toughbook CF-53 Wi-Fi Card Replacement: step 2, image 1 of 2 Panasonic Toughbook CF-53 Wi-Fi Card Replacement: step 2, image 2 of 2
    • Very gently pry up on the two connectors attached to the Wi-Fi card using the flat end of a spudger.
    • It is very important to be careful with these connectors because they are difficult to replace or repair.
    • Once both connectors have been detached, carefully hold the wires back to have access to the Wi-Fi card.
  3. Panasonic Toughbook CF-53 Wi-Fi Card Replacement: step 3, image 1 of 3 Panasonic Toughbook CF-53 Wi-Fi Card Replacement: step 3, image 2 of 3 Panasonic Toughbook CF-53 Wi-Fi Card Replacement: step 3, image 3 of 3
    • Remove the two 4 mm Phillips #00 screws that secure the card to the board.
    • Gently lift the card up and pull it out of its connection slot.
    • The Wi-Fi card is now removed.
    • When inserting the new Wi-Fi card into the connection slot, place the card at a 40 degree angle and push it all the way back, then lay it flat.
0 Comments
Past 24 Hours: 5
Past 7 Days: 10
Past 30 Days: 70
All Time: 3,021
