Panasonic VDR-D220 DVD Disk Latch Replacement
  1. Panasonic VDR-D220 DVD Disk Latch Replacement, Disk Latch: step 1, image 1 of 2 Panasonic VDR-D220 DVD Disk Latch Replacement, Disk Latch: step 1, image 2 of 2
    • The DVD's door can be opened by pressing the top-left of the DVD's door.
    • If this doesn’t work, you may need to manually eject.
    • Use the plastic spudger with light force to carefully pry open the door.
    • Open the disk ejection slot gently.
  2. Panasonic VDR-D220 DVD Disk Latch Replacement: step 2, image 1 of 3 Panasonic VDR-D220 DVD Disk Latch Replacement: step 2, image 2 of 3 Panasonic VDR-D220 DVD Disk Latch Replacement: step 2, image 3 of 3
    • Remove the two 5mm screws on the top-right corner of the disk slot using Phillips #0 screwdriver.
  3. Panasonic VDR-D220 DVD Disk Latch Replacement: step 3, image 1 of 2 Panasonic VDR-D220 DVD Disk Latch Replacement: step 3, image 2 of 2
    • Carefully remove the chip.
    • The disk is completely replaced/removed.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 144
