Pandigital Novel PRD07T10WWH7 SD Card Replacement
  1. Pandigital Novel PRD07T10WWH7 SD Card Replacement, SD Card: step 1, image 1 of 3 Pandigital Novel PRD07T10WWH7 SD Card Replacement, SD Card: step 1, image 2 of 3 Pandigital Novel PRD07T10WWH7 SD Card Replacement, SD Card: step 1, image 3 of 3
    • Remove the two white panels on the back of the device, starting with the bottom one by pushing in and down.
    • Then, to remove the top white piece, use the plastic opening tool to start in the middle and remove the clips, working your way around.
  2. Pandigital Novel PRD07T10WWH7 SD Card Replacement: step 2, image 1 of 1
    • Using a Phillips #0 bit, remove the 12 4mm screws.
  3. Pandigital Novel PRD07T10WWH7 SD Card Replacement: step 3, image 1 of 3 Pandigital Novel PRD07T10WWH7 SD Card Replacement: step 3, image 2 of 3 Pandigital Novel PRD07T10WWH7 SD Card Replacement: step 3, image 3 of 3
    • Pry the gray piece off of the motherboard.
    • Make sure the unplug the battery before you fully separate the gray piece.
  4. Pandigital Novel PRD07T10WWH7 SD Card Replacement: step 4, image 1 of 2 Pandigital Novel PRD07T10WWH7 SD Card Replacement: step 4, image 2 of 2
    • Push upwards on the SD card slot to release it.
  5. Pandigital Novel PRD07T10WWH7 SD Card Replacement: step 5, image 1 of 2 Pandigital Novel PRD07T10WWH7 SD Card Replacement: step 5, image 2 of 2
    • The SD card can now be removed safely.
Carl Weber
328 Reputation
2 Guides authored
UMass Dartmouth, Team 3-7, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G7
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 432
