Pandigital Novel PRD07T10WWH7 Wireless Card Replacement
  1. Pandigital Novel PRD07T10WWH7 Wireless Card Replacement, Wireless Card: step 1, image 1 of 1
    • Remove the back panel by sliding it downwards and pushing in slightly.
  2. Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: step 2, image 1 of 2 Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: step 2, image 2 of 2
    • Pry off the second white panel, removing two clips underneath.
    • Start from the middle, and then work on the sides. The sides may be difficult to remove, so try to focus on one side and work your way around.
  3. Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: step 3, image 1 of 1
    • Using a Phillips #0 bit, remove the 12 4mm screws.
  4. Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: step 4, image 1 of 3 Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: step 4, image 2 of 3 Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: step 4, image 3 of 3
    • Pry off the gray piece by removing the clips around it.
    • Then, unplug the battery and separate the gray piece from the motherboard
  5. Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: step 5, image 1 of 2 Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: step 5, image 2 of 2
    • Using a Phillips #0 bit, remove the two 3mm screws at the top of the wireless card.
  6. Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: step 6, image 1 of 2 Pandigital Novel PRD07T10WWH7 Wireless Card Replacement: step 6, image 2 of 2
    • Unplug the wire from the wireless card.
    • Flip up the retaining flap, releasing the card.
Samuel Carey
401 Reputation
3 Guides authored
UMass Dartmouth, Team 3-7, Isaacson Fall 2016 Member of UMass Dartmouth, Team 3-7, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G7
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 176
