Pantech Breakout Battery Replacement
  1. Pantech Breakout Battery Replacement, Removing Back Cover: step 1, image 1 of 3 Pantech Breakout Battery Replacement, Removing Back Cover: step 1, image 2 of 3 Pantech Breakout Battery Replacement, Removing Back Cover: step 1, image 3 of 3
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
  2. Pantech Breakout Battery Replacement, Removing the Battery: step 2, image 1 of 2 Pantech Breakout Battery Replacement, Removing the Battery: step 2, image 2 of 2
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
Ryan Murphy
898 Reputation
7 Guides authored
USF Tampa, Team 5-5, Mcgee Fall 2014 Member of USF Tampa, Team 5-5, Mcgee Fall 2014
USFT-MCGEE-F14S5G5
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,928
