Pantech Breakout Micro SD/SIM Card Replacement
  1. Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: step 1, image 1 of 3 Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: step 1, image 2 of 3 Pantech Breakout Micro SD/SIM Card Replacement, Removing Back Cover: step 1, image 3 of 3
    • Before proceeding, completely power off phone and disconnect power cords to avoid electrical shock.
    • Turn phone over so that the back side is facing up.
    • Using a finger, apply moderate pressure to the top of the back cover while sliding the cover down and off.
    • Lift and remove the back cover from the phone.
  2. Pantech Breakout Micro SD/SIM Card Replacement, Removing the Battery: step 2, image 1 of 2 Pantech Breakout Micro SD/SIM Card Replacement, Removing the Battery: step 2, image 2 of 2
    • Locate the battery: It is a silver, rectangular object.
    • Insert a fingernail into the indent just below the battery about 0.5 inches from the bottom of the phone.
    • Then, apply pressure to the battery, pushing up and away from the phone. It will come out easily.
  3. Pantech Breakout Micro SD/SIM Card Replacement, Inserting Micro SD or SIM Card: step 3, image 1 of 2 Pantech Breakout Micro SD/SIM Card Replacement, Inserting Micro SD or SIM Card: step 3, image 2 of 2
    • The slots for the Micro SD and SIM cards are directly above the battery tray.
    • To insert a card, slide it face up into the slot. To remove a card, slide the card out from the slot.
    • Micro SD Card Slot - On the Left
    • SIM Card Slot - On the Right
3 other people completed this guide.
Ryan Murphy
898 Reputation
7 Guides authored
USF Tampa, Team 5-5, Mcgee Fall 2014 Member of USF Tampa, Team 5-5, Mcgee Fall 2014
USFT-MCGEE-F14S5G5
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 2,795
