Pantech CDM8975 Keyboard Replacement
  1. Pantech CDM8975 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Remove the battery.
    • Remove four Phillips screws.
  2. Pantech CDM8975 Keyboard Replacement: step 2, image 1 of 1
    • Pry up the plastic layer with a plastic opening tool.
    • NOTE: Be careful that you do not separate the two plastic parts completely they are fragile and may break if pulled too hard.
  3. Pantech CDM8975 Keyboard Replacement, Remove Keyboard: step 3, image 1 of 1
    • Slide out the keyboard carefully in between the two layers.
  4. Pantech CDM8975 Keyboard Replacement: step 4, image 1 of 1
    • Insert the new keyboard in between the two layers carefully.
  5. Pantech CDM8975 Keyboard Replacement: step 5, image 1 of 1
    • Check if the edges are perfectly aligned between the two plastic layers after you insert the keyboard.
  6. Pantech CDM8975 Keyboard Replacement: step 6, image 1 of 1
    • Press the two plastic layers back together.
    • Reinsert the four screws and place the battery and cover back.
You now have a new keyboard.
2 other people completed this guide.
Richard
116 Reputation
1 Guide authored
Ohio State, Team 1-4, Meza Spring 2014 Member of Ohio State, Team 1-4, Meza Spring 2014
OSU-MEZA-S14S1G4
4 Members
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 360
