Pantech Matrix Power Button Replacement
  1. Pantech Matrix Power Button Replacement, Phone Orientation: step 1, image 1 of 1
    • Place phone with screen side facing toward you.
  2. Pantech Matrix Power Button Replacement, Phone Orientation: step 2, image 1 of 1
    • Flip phone over so screen side is now facing down.
  3. Pantech Matrix Power Button Replacement, Remove Back Cover: step 3, image 1 of 2 Pantech Matrix Power Button Replacement, Remove Back Cover: step 3, image 2 of 2
    • Gently slide the backside phone cover off exposing the battery underneath.
  4. Pantech Matrix Power Button Replacement, Lift Battery: step 4, image 1 of 1
    • Carefully lift the battery up from where the spudger is pointed.
  5. Pantech Matrix Power Button Replacement, Remove Battery: step 5, image 1 of 1
    • Remove the battery from its dock.
  6. Pantech Matrix Power Button Replacement, Slide SIM Card Out: step 6, image 1 of 3 Pantech Matrix Power Button Replacement, Slide SIM Card Out: step 6, image 2 of 3 Pantech Matrix Power Button Replacement, Slide SIM Card Out: step 6, image 3 of 3
    • Slide the SIM Card out of its dock.
  7. Pantech Matrix Power Button Replacement, Remove Phone Screws: step 7, image 1 of 2 Pantech Matrix Power Button Replacement, Remove Phone Screws: step 7, image 2 of 2
    • Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
  8. Pantech Matrix Power Button Replacement, Remove Phone Casing: step 8, image 1 of 2 Pantech Matrix Power Button Replacement, Remove Phone Casing: step 8, image 2 of 2
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside.
  9. Pantech Matrix Power Button Replacement, Remove Camera Screws: step 9, image 1 of 2 Pantech Matrix Power Button Replacement, Remove Camera Screws: step 9, image 2 of 2
    • Place phone with exposed motherboard facing you.
    • Use a PH000 driver to remove the five 2 mm screws holding the camera in place.
  10. Pantech Matrix Power Button Replacement, Remove Motherboard: step 10, image 1 of 1
    • Carefully lift up to motherboard to expose the power button.
  11. Pantech Matrix Power Button Replacement, Remove Power Button: step 11, image 1 of 2 Pantech Matrix Power Button Replacement, Remove Power Button: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • Locate the power button.
    • Grasp the power button with metal tweezers and pull gently to remove.
2 other people completed this guide.
Zeel Patel
1,096 Reputation
9 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 432
