Parrot AR.Drone 2.0 Hull Replacement
Video Overview
  1. Parrot AR.Drone 2.0 Hull Replacement, Hull: step 1, image 1 of 2 Parrot AR.Drone 2.0 Hull Replacement, Hull: step 1, image 2 of 2
    • Peel off double sided tape and apply to one side of the broken hull.
  2. Parrot AR.Drone 2.0 Hull Replacement: step 2, image 1 of 2 Parrot AR.Drone 2.0 Hull Replacement: step 2, image 2 of 2
    • Cut the tape with scissors as close to the shape of the broken hull as possible.
  3. Parrot AR.Drone 2.0 Hull Replacement: step 3, image 1 of 2 Parrot AR.Drone 2.0 Hull Replacement: step 3, image 2 of 2
    • Peel off the other side of the tape and stick the two sides together.
David Hoyt
4,023 Reputation
43 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
63 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,521
