Parrot AR.Drone 2.0 Motor Replacement
David Hoyt
David Hoyt and 10 other contributors
Last updated on November 24, 2017
15 - 20 minutes
Easy
Introduction
Go to step 1
Use this guide to diagnose and replace a faulty motor on your Parrot AR.Drone 2.0.
AR.Drone 2.0 spare parts and mounting tools are available from several Parrot retailers.
Parts
Tools
Show more…
iFixit earns commission when you buy through these links.
Video Overview
  1. Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: step 1, image 1 of 2 Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: step 1, image 2 of 2
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Motor Replacement: step 2, image 1 of 2 Parrot AR.Drone 2.0 Motor Replacement: step 2, image 2 of 2
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Motor Replacement: step 3, image 1 of 1
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Motor Replacement: step 4, image 1 of 3 Parrot AR.Drone 2.0 Motor Replacement: step 4, image 2 of 3 Parrot AR.Drone 2.0 Motor Replacement: step 4, image 3 of 3
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
  5. Parrot AR.Drone 2.0 Motor Replacement, Motor: step 5, image 1 of 2 Parrot AR.Drone 2.0 Motor Replacement, Motor: step 5, image 2 of 2
    • Disconnect the connector at the bottom of the motor assembly.
  6. Parrot AR.Drone 2.0 Motor Replacement: step 6, image 1 of 1
    • Remove the three 5mm screws on the top of the motor assembly with a PH00 bit.
  7. Parrot AR.Drone 2.0 Motor Replacement: step 7, image 1 of 1
    • Remove the three 5mm screws on the bottom again using a PH00 bit.
    • The three screws from the top are different from the three screws on the bottom.
  8. Parrot AR.Drone 2.0 Motor Replacement: step 8, image 1 of 2 Parrot AR.Drone 2.0 Motor Replacement: step 8, image 2 of 2
    • Carefully wiggle out the motor assembly out of the arm.
5 other people completed this guide.
David Hoyt
4,053 Reputation
41 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
61 Guides authored
2 Comments
are the motors different on each side?
dbksoft - Reply
I need to know this also. replaced cross.member but did not put motors in original spots now my drone goes crazy and erratic
Steven Maloney -
Past 24 Hours: 0
Past 7 Days: 26
Past 30 Days: 41
All Time: 5,854
