Parrot AR.Drone 2.0 Propeller and Gear Replacement
Video Overview
  1. Parrot AR.Drone 2.0 Propeller and Gear Replacement, Propeller and Gear: step 1, image 1 of 2 Parrot AR.Drone 2.0 Propeller and Gear Replacement, Propeller and Gear: step 1, image 2 of 2
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Propeller and Gear Replacement: step 2, image 1 of 2 Parrot AR.Drone 2.0 Propeller and Gear Replacement: step 2, image 2 of 2
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Propeller and Gear Replacement: step 3, image 1 of 1
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Propeller and Gear Replacement: step 4, image 1 of 3 Parrot AR.Drone 2.0 Propeller and Gear Replacement: step 4, image 2 of 3 Parrot AR.Drone 2.0 Propeller and Gear Replacement: step 4, image 3 of 3
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
4 other people completed this guide.
David Hoyt
4,023 Reputation
43 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
63 Guides authored
One Comment
any idea how to change the little gear?
Dar BS - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 26
All Time: 8,424
