Introduction
This guide will show the steps needed to remove the EPP (Expanded Polypropylene) or Styrofoam Nose. The Styrofoam nose protects the motherboard and the GPS Module. In order to remove the Nose, the battery will have to be removed first.
Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
To reassemble your device, follow these intructions in reverse order
2 other people completed this guide.
