Parrot FLYPAD Battery Replacement
  1. Parrot FLYPAD Battery Replacement, Battery: step 1, image 1 of 1
    • Use a T6 screwdriver to remove the six screws from the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
  2. Parrot FLYPAD Battery Replacement: step 2, image 1 of 1
    • Use a screwdriver to remove the two 0.7 mm screws from the battery cover.
  3. Parrot FLYPAD Battery Replacement: step 3, image 1 of 1
    • Separate the plastic cover from battery.
    • Avoid damaging the wires and gently remove the battery from the motherboard.
  4. Parrot FLYPAD Battery Replacement: step 4, image 1 of 1
    • Use fingers to gently detach the battery wires from the motherboard.
  5. Parrot FLYPAD Battery Replacement: step 5, image 1 of 1
    • Gently attach the wire connection from the new battery to the motherboard. Avoid touching the motherboard directly.
HUY NGUYEN
376 Reputation
3 Guides authored
UW Tacoma, Team S3-G5, Liner Spring 2017 Member of UW Tacoma, Team S3-G5, Liner Spring 2017
UWT-LINER-S17S3G5
5 Members
3 Guides authored
3 Guide Comments
Where did I get a new battery? Can’t find one.
Randy - Reply Share
Sorry where do I get a new parrot flypad battery. From Randy
Randy - Reply Share
where do I get a battery for this repair?
Philip Pepin - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 1,243
